Duggs
Jun 24, 2018Tutor
I can't connect iOS to Brother printer
Hi all, I’m desperately trying to connect my iOS device to my Brother MFC-J625W printer. There is already a Windows laptop connected with a USB cable and by wifi to the printer and a C7000 Night...
Mark96
Apr 29, 2019Aspirant
Normally, People can't connect their printer to the IOS device due to the few reasons.
1. Network communication problem.
2. Firewall issue.
3. Driver issue.
Now let me give you the instructions to fix the problem.
1. Be sure your printer and IOS devices is connected from same network. If they are not connected yet. you should go ahead and connected them right now.
2. Also, you should check firewall and antivirus settings.be sure,your antivirus or firewall is not blocking the printer. so you should turn off the security and then try to connect your printer now.
3. If you get brother pritner offline error during printing or scaning a document on any device. you should uninstall the printer and reinstall it once again.
4. After following all these instructions, if your pritner doesn't work for you yet. you should reset your printer to the factory settings and reconfigure it again. I am sure your printer will start working fine.
