Kakashi2000's avatar
Aug 04, 2016
I hope the next gen modem dont have problems like c7000
like network droping
some feature not work correcly
dns detection and disconect problem
uncompavility with other nat event if you put dmz still uncompatible
disconnection playing on lines games
lan not detecting devices some times
dos and portscan not work disconect you if you leave it enable for a period of time
first modem damage with a speed of 300mbs  you sure your hardware is strong to run extreme speed or higher
ect
i hope the next gen modem  dont have any fimware error or bugs or fimware corruption
dont reaaly like to waste money
make all this
I hope you make a extreme modem
super fast software and extreme stavility fimware and hardware
no disconection online ,no higth ping ,no higth latency ,no lag spikes,no drops network speed.. no lag server compensation or,swich lag on games
make super extreme lan gigagit network speed and turbo 2gigabit or higth
new ddr4 1 gb memory for extremje performance
new extreme cpu 4 core or 6 core 2.40ghz or highter  for extreme gaming
new lan and wirless acelearation for extreme low ping and super fast trafic  for long distance servers distance so you can travel super fast
new 4 modem or 6 modem in one hardware
new 8 lan or 10 lan extreme gaming
new frontal cristal beautiful design with new hd ligth led
new lan metal design ,why not plastic plastic cold broke so is better metal lan and new led design
new futuristic design modem
new cox voltage protection and thunder protection
new higth strong voltage protection hardware and capacitor for strong resistance voltage damage and himidity ect
strong voltage noise protection and static cox ect
new next gen firewall and security network turbo
new anti haker prevention
new dos,ddos,deep port scan and anti exploit tech
new zero day attacks and new uknow attacks
new ipv6 and security
new vpn
new upnp tech and security
new https or higther security login
new spectrum voltage analiser
make sure all chanels activate or cold be active over the modem
make sure download and upload have to change frecuency chanels and voltage too and organise chanels ect
make turbo chanels download and upload
make 32chanels upload and 32 download why upload for uknow reason is always low fix that
make sure support all frecuency and all modulation and new modulation and new freacuency for upload and download
new fimware backup and fimware repair for any error
ect just helping you  make the next masterpiece
1 Reply
  • not sure if netgear is the maker of the the product you speak of, but its already out. NASA is using it to power all its systems here on Earth. Id grab one at BBuy but the billion plus price is out of my range. dang. but hey, this thing in my hand is way better than the tech used to go to the moon so who knows.
