itsmejustin25
Aug 20, 2016Aspirant
Intermittent wireless Internet drops
Model: C3000 Firmware: V2.02.08 OS: OSX 10.11.6 I'm having an increasingly technically issue where my wireless connection drops and all my connected devices are not able to connect to the Inter...
DarrenM
Aug 24, 2016Sr. NETGEAR Moderator
Hello itsmejustin25
In you router go to Advanced-Setup-Wan Setup and make sure disable Port Scan and Dos Protection is unchecked see if this will stop the DOS attacks and see if this the cause of the disconnects.
DarrenM
itsmejustin25
Aug 24, 2016Aspirant
Hi Darren
I unchecked the box. Hopefully this resolved this issue.
Thanks
