NetGuy123
Sep 25, 2015Aspirant
Invalid Data. Lan IP Address Overlapped! - N600 / C3700
Hi, When trying to change the LAN Setup original IP setting of 192.168.0.1 to 192.168.100.1, I get this error in the Subject: Invalid Data. Lan IP Address Overlapped! After reading the manua...
DarrenM
Sep 28, 2015Sr. NETGEAR Moderator
Hello NetGuy
What all is on your network now just the C3700 and the devices that connect to it or is there another router? and how are you connecting to the C3700 via wireless or LAN? Hope to hear your feedback
DarrenM
NetGuy123
Sep 28, 2015Aspirant
Hi Darren,
Thank you for yor attention to this.
I have a network printer, W10 on a laptop, a w7 on a DT and smart TV, not to mention a smartphine and a tablet. I use fixed IP on the ethernet side for printer, LT and DT, everything else DHCP assigned IP.
Fixed IP on LT and DT is for remote access purposes, mainly.
I have already uninstalled the eth adapters a few times, and reinstalled back with the latest drivers, but to no avail.
I also added back the PR2000, set its DHCP for 192.168.100.0 network again and played a while with it, then logged off by signing out from it before turning it off and disconnecting it
Then back to C3700, but the issue remains, able to assign 192.168.N.0, where N can be anything from1 to 254, except for 100. It doesn't like the private network be 192.168.100.0 at all!
I also reset C3700 a few times, but the message is the same....
It's interesting that, with the C3700 connected and working using 192.168.101.o, if I type 192.168.100.1 for the URL, it goes to http://192.168.100.1/MultiLogin.htm and shows in the screen a logo from C3700 with this message:
-------> START OF MESSAGE <-----
You are currently logged in from another device. There can be only one device logged in at a time. If you log in from this device, the other device will be logged out. Do you want to proceed?
-------> END OF MESSAGE <-----
PR2000 is not in the loop, I mean, is not connected or attached in any way to the network...
Besides C3700, only a switch is in the network, which doesn't care about the network layer... And I tested removing it from the network, no use at all either...
Thanks for your time and attention.
