Trex0321
Dec 12, 2018Aspirant
IP Addressing
ok, hi, first of all, my netgear router is a r6020. its not selectable.
anyways,
i set it up correctly and can browse the internet and use wifi, however, my pc has the ipaddress 10.0.0.3...
- Dec 12, 2018
> [...] first of all, my netgear router is a r6020. its not selectable.
Not in the "Cable Modems & Routers" forum, no. You'd have a better
chance in an appropriate forum:
https://community.netgear.com/t5/x/bd-p/home-wifi-routers-r6000-series
Except that some sub-genius at Netgear disabled that one, apparently
leaving lower R6xxx models, like the R6020, homeless.
> [...] my pc has the ipaddress 10.0.0.3. [...]
> this router is connected to the modem via 5e ethernet cable, which is
> in fact a modem router, and that has the ip address 192.168.1.1.
That's what happens when you cascade multiple routers.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "Use the Router as a
WiFi Access Point Only".
antinode
Dec 12, 2018Guru
