Trex0321's avatar
Trex0321
IP Addressing
ok, hi, first of all, my netgear router is a r6020. its not selectable.   anyways,    i set it up correctly and can browse the internet and use wifi, however, my pc has the ipaddress 10.0.0.3...
  • antinode's avatar
    Dec 12, 2018
    > [...] first of all, my netgear router is a r6020. its not selectable.
       Not in the "Cable Modems & Routers" forum, no.  You'd have a better
    chance in an appropriate forum:
          https://community.netgear.com/t5/x/bd-p/home-wifi-routers-r6000-series
    Except that some sub-genius at Netgear disabled that one, apparently
    leaving lower R6xxx models, like the R6020, homeless.
    > [...] my pc has the ipaddress 10.0.0.3. [...]
    > this router is connected to the modem via 5e ethernet cable, which is
    > in fact a modem router, and that has the ip address 192.168.1.1.
       That's what happens when you cascade multiple routers.
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Look for "Use the Router as a
    WiFi Access Point Only".
