cliffkeller's avatar
cliffkeller
Follower
Feb 11, 2018
Lan compatibility
Do i need to be concerned about CAT 5 a and b, or CAT 6 compatibility between my CG4500 and my motorola 7550?  I want to connect them via a LAN CAT5 cable from one end of my home to the other.
1 Reply
  • > Do i need to be concerned about CAT 5 a and b, or CAT 6 compatibility
       I don't know what "CAT 5 a and b" means to you, or what either of
    those (non-?) model numbers might signify, but either Cat5e or Cat6
    should work for gigabit (1000Mb/s) Ethernet (for up to 100m).
          https://en.wikipedia.org/wiki/Category_5_cable
