Lestdog's avatar
Lestdog
Login Page for CM1000v2 just refreshes when I try to login
When I go to http://192.168.100.1. and try and login, nothing happens but a page refresh. I did a factory rest and tried "admin" & "password" and again. The page just resets the login form.
Any idea's ? Thanks community!
  • Definitely check to see if you can get it RMAd. Ya seems like something is borked on the web page service side.
    Good Luck.
  • plemans's avatar
    Try a different browser and/or pc.
    Also, when you reset, did you push and hold for up to 15 seconds while powered on.
    • Lestdog's avatar
      Lestdog
      Hello, thanks but yeah I did all those and just did them again. Page just refreshes and clears the login form. Any other ideas?
      Thanks again.
      • plemans's avatar
        make sure to have password managers disabled.
        make sure there isn't any spaces in the default settings.
        Also, try disconnecting the coax cable.
        What browsers did you use?
