robertb2's avatar
robertb2
Looking for a Netgear Router Recommendation
Can someone please suggest a Netgear router that supports assigning a block of 5 static ip address attached to different servers? I am in the process of migrating my internet from Uverse to WOW. My U...
  • TheEther's avatar
    Aug 05, 2017
    None of the Home Networking routers offerred by Netgear can handle a block of static IP addresses unless you load third-party firmware.  You'll need to step up to their Business Networking gear, specifically their UTM and VPN firewalls.
    In that space, you may also want to consider a Ubiquiti Edgerouter.  While it has a GUI, some of the advanced functions are only accessible through the CLI.  It may be possible to set up a static block through the GUI.  I'm just not sure because I've never tried it.
