Steve_Y's avatar
Steve_Y
Looking for wired router compatible with CM1000 link aggregation
I have a CM1000 cable modem.  It has two gigabit ports that can be used together via link aggregation.  I'm looking for a reasonably priced wired router that supports the protocol.  The router will be the networks DHCP server.  I do not need VPN.   Any suggestions?
  • FURRYe38's avatar
    Ubiquity Edge Router X is a wired only router. Any router will work.
  • plemans's avatar
    The CM1000 doesn't have 2x ports. Only 1.
    The CM1100 does have dual and supports link aggregation
    • Steve_Y's avatar
      Steve_Y
      Sorry, yes.  it's a CM1100.  I'm looking for a wired router to use the link aggregation with it. I want the wired router to be my DHCP server for the rest of the network.  Any suggestions?
      • plemans's avatar
        Whats you're budget? My reasonalbe might be a bit different than yours.
        Also, there's options like FURRYe38 suggested going with the Edge RouterX for just a hardwired router and using your current device (if you have one) for access point (wireless). Sometimes a cheaper option.
        by looking at the "supported models" for setting up wan port aggregation, it can give you an idea of what routers support it.
        How do I set up WAN (Internet) Ethernet port aggregation on my NETGEAR Nighthawk router? - NETGEAR Support
        Gives you options from high end AC devices, to the AX or BE devices. So a spread of generations
