B1363
Apr 18, 2020Follower
Model C7800 Computer Unable to connect using VPN
I'm trying to work from home but my computer will not connect through the VPN. I'm using Dell Sonicwall Global VPN Client with Windows 10. The computer will connect through the VPN at other sites, so IT thinks it's our router that is cousing the problem. Our router is the AC3200 model C7800 with Cox cable. I have read many tips related to different routers but this router is different so non of the solutions work.
B1363 wrote:I'm trying to work from home but my computer will not connect through the VPN. I'm using Dell Sonicwall Global VPN Client with Windows 10. The computer will connect through the VPN at other sites, so IT thinks it's our router that is cousing the problem. Our router is the AC3200 model C7800 with Cox cable. I have read many tips related to different routers but this router is different so non of the solutions work.
Your companies IT thinks that?
Did you try contacting the VPN provider "sonicwall"?
Maybe they know what specifics need to be done for their vpn client to run on specific devices.
- HughleAspirant
Yes, I have the same problem that with VPN connection after deploying C7800 router to my network. If I don't have it resolved this week, I think I have to return the router.
