the87hyper
Sep 06, 2024Aspirant
Modem....CM10000v2
So is my modem done, or just need reprogrammed? Its dropping internet.....
| Time | Priority | Description |
| 2024-09-06, 19:25:34 | Warning (5) | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; |
| 2024-09-06, 19:25:34 | Notice (6) | US profile assignment change. US Chan ID: 8; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; |
| 2024-09-06, 19:20:28 | Warning (5) | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; |
| 2024-09-06, 19:20:28 | Notice (6) | US profile assignment change. US Chan ID: 8; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; |
| 2024-09-06, 10:01:32 | Warning (5) | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; |
| 2024-09-06, 10:01:32 | Notice (6) | US profile assignment change. US Chan ID: 8; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; |
| 2024-09-06, 08:35:09 | Warning (5) | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; |
| 2024-09-06, 08:35:09 | Notice (6) | US profile assignment change. US Chan ID: 8; Previous Profile: 13; New Profile: 12 13.;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; |
| 2024-09-06, 08:30:03 | Error (4) | Improper Configuration File CVC Format |
| 2024-09-06, 08:29:57 | Warning (5) | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; |
| 2024-09-06, 08:29:55 | Notice (6) | DS profile assignment change. DS Chan ID: 33; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; |
| 2024-09-06, 08:29:55 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; |
| 2024-09-06, 08:29:50 | Notice (6) | TLV-11 - unrecognized OID;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; |
| 2024-09-06, 08:29:47 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = IPv4 |
| Time Not Established | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| 2024-09-06, 08:28:51 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
got a screensnip of the cable connections page with the logs?
- the87hyperAspirant
arting Frequency <tabindex=-1>Startup Procedure</tabindex=-1>
Procedure Status Comment Acquire Downstream Channel 645000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enable BPI+ IP Provisioning Mode Honor MDD IPv4 only <tabindex=-1>Downstream Bonded Channels</tabindex=-1>
Channel Lock Status Modulation Channel ID Frequency Power SNR / MER Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked QAM256 12 645000000 Hz 9.0 dBmV 40.9 dB 1471353494 0 0 2 Locked QAM256 3 591000000 Hz 7.6 dBmV 40.1 dB 1470640845 0 0 3 Locked QAM256 4 597000000 Hz 7.7 dBmV 40.2 dB 1470644264 0 0 4 Locked QAM256 5 603000000 Hz 8.1 dBmV 40.3 dB 1470648586 0 0 5 Locked QAM256 6 609000000 Hz 8.1 dBmV 40.3 dB 1470652597 0 0 6 Locked QAM256 7 615000000 Hz 8.5 dBmV 40.6 dB 1470656237 0 0 7 Locked QAM256 8 621000000 Hz 8.5 dBmV 40.6 dB 1470660257 0 0 8 Locked QAM256 9 627000000 Hz 8.5 dBmV 40.7 dB 1470664169 0 0 9 Locked QAM256 10 633000000 Hz 8.6 dBmV 40.5 dB 1470667908 0 0 10 Locked QAM256 11 639000000 Hz 8.8 dBmV 40.9 dB 1470671105 0 0 11 Locked QAM256 13 651000000 Hz 9.1 dBmV 41.0 dB 1470674878 0 0 12 Locked QAM256 14 657000000 Hz 9.0 dBmV 41.2 dB 1470679062 0 0 13 Locked QAM256 15 663000000 Hz 9.2 dBmV 41.2 dB 1470682099 0 0 14 Locked QAM256 16 669000000 Hz 8.8 dBmV 41.1 dB 1470685628 0 0 15 Locked QAM256 17 675000000 Hz 9.3 dBmV 40.8 dB 1470683875 0 0 16 Locked QAM256 18 681000000 Hz 9.3 dBmV 41.3 dB 1470687664 0 0 17 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 18 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 19 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 20 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 21 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 22 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 23 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 24 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 25 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 26 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 27 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 28 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 29 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 30 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 31 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 <tabindex=-1>Upstream Bonded Channels</tabindex=-1>
Channel Lock Status Modulation Channel ID Frequency Power 1 Locked ATDMA 1 17300000 Hz 37.8 dBmV 2 Locked ATDMA 2 23700000 Hz 37.8 dBmV 3 Not Locked Unknown 0 0 Hz 0.0 dBmV 4 Not Locked Unknown 0 0 Hz 0.0 dBmV 5 Not Locked Unknown 0 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Hz 0.0 dBmV <tabindex=-1>Downstream OFDM Channels</tabindex=-1>
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier Number Range Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked 0, 1, 2, 3 159 276000000 Hz 3.7 dBmV 35.8 dB 886 ~ 3209 7043718667 1276189869 0 2 Locked 0, 1, 2, 3 160 810000000 Hz 9.3 dBmV 33.8 dB 166 ~ 3929 11434663251 1783583421 0 <tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Locked 3, 4, 9, 10, 11, 12, 13 3 23700000 Hz 33.3 dBmV 2 Not Locked 3, 4, 9, 10, 11, 12, 13 0 0 Hz 0.0 dBmV - the87hyperAspirant
2024-09-07, 18:02:51 Warning (5) DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; 2024-09-07, 18:02:51 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; 2024-09-07, 17:57:46 Warning (5) DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; 2024-09-07, 17:57:46 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; 2024-09-07, 17:42:30 Warning (5) DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; 2024-09-07, 17:42:30 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; 2024-09-07, 17:37:26 Warning (5) DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; 2024-09-07, 17:37:26 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; 2024-09-07, 17:32:24 Warning (5) DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; 2024-09-07, 17:32:24 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; 2024-09-07, 17:17:13 Warning (5) DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1; 2024-09-07, 17:17:13 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=6c:cd:d6:94:14:5c;CMTS-MAC=00:38:df:9b:4e:3d;CM-QOS=1.1;CM-VER=3.1;
