kkester
Nov 03, 2021Tutor
Modem CM700 Ethernet light is blinking orange/flickering orange.
Is this an issue? All of the lights are solid green besides that one and I have internet connection. Just want to know if this is an issue or will I continue to get steady connection?
- FURRYe38Guru - Experienced UserWhat is the brand and model of the host wifi router connected to the modem? The ethernet LED should indicate "Green" for 1000Mpbs and If it's "Amber" then it maybe indicating a 100Mpbs connection with your external wifi router or the computer you have connected to it. Review the user manual to see what the LED behaviors are for the modem. - kkesterTutorLinksys AC1200- FURRYe38Guru - Experienced UserReview the specs sheet for that model router if this is the one you have: https://downloads.linksys.com/support/assets/datasheet/e5400-router-ac1200-datasheet-upd-eng.pdf
