AlistairPhoenix's avatar
Jun 29, 2017
Modems rebooting after heavy use
After about 4 cable technicians and many nights of constant failures, I wanted to turn to the internet for answers.
In the past month, my modem is constantly rebooting itself after 4 or so hours of constant use. This is especially annoying since I play online games and having to be disconnected for brief moments.
My cable provider is Suddenlink and I have had them for 2 1/2 years. The only problems I had with them was when I needed their rental modem replaced. After 2 years, I decided to get my own modem to save on money. My first modem was an Arris Surfboard Cable Modem Model SB6141.
It was working just fine up until recently. I could surf the web and I could play my games without fear of having a random disconnect. So to have it start after a few months of use was worrying. So I decided to do a bit of troubleshooting. I first started with power cycling and factory reseting. Didn't work. I then tried getting a UPS and giving it its own power source. The modem still rebooted itself after a few hours of use. I tried to see if heating was an issue. My room is well ventilated and is constantly at low tepperature with a fan blowing through the room. I then replaced my modem with the CM400 Netgear modem to see if that would work.
Nope.
It did the same thing as the other modem. So, then I called the technicians out there. The first technician removed a filter on the line to see if that worked. He leaves, I start using the internet. 4 hours later, the modem reboots itself. I call a 2nd technician out here. This technician gives me my own line and even replaced the splitter I was attached to and puts it on a three way splitter.
For reference, the cable reaches from at least 3 poles and to a 2 way splitter before they attache another cable that is covered and buried underground. The coaxial cable is then brought through the floor of the trailer and attached to the modem.
4 hours later, modem reboots.
I then call a third tech to see if they would know anything else to replace. The guy just tests the connection and tells me that I either have a grounding issue or an electric issue. My trailer has a grounding box and everything in the trailer has been working fine, no fluctuations or anything. He also mentions that the SNR was fine and passable. So he just places another splitter on the line; this time inside the trailer before it hits the box.
I checked the logs for my modem and saw that the power levels as well as the noise was well within the recommended range and yet when I look at my logs I keep seeing T3 Timeouts every so often.
I called a fourth tech out today. It was the same guy as last time. All he does it check the connection on his equipment, tell me nothing is wrong, and leaves but not before saying something about seeing if I have a grounding issue or an electrical issue.
This is the only cable internet service I have in the area and nobody even knows what is going on with my modems.
When I say "reboot", I mean that all the lights, except for the power light, goes out and slowly blink back on.
Is there anyone here that has an idea as to what the problem really is?
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    Can you please post event log and power table for us to review?
  • Event Log
    Time Not Established Critical (3) DHCP failed - RS sent, no RA received
    Time Not Established Error (4) Primary lease failed, IPv4 fallback initiated
    Jul 4 17:07:10 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
    Time Not Established Critical (3) No Ranging Response received - T3 time-out
    Jul 4 20:11:07 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
    Jul 4 23:03:26 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
    Jul 5 04:04:43 2017 Warning (5) Lost MDD Timeout
    Jul 5 04:05:42 2017 Critical (3) No Ranging Response received - T3 time-out
    Jul 5 04:06:36 2017 Warning (5) Lost MDD Timeout
    Jul 5 10:09:15 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
    Jul 5 14:09:47 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
    Jul 5 17:56:59 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
    Jul 5 22:54:27 2017 Warning (5) Lost MDD Timeout
    Jul 5 23:18:55 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
    Jul 6 04:18:12 2017 Warning (5) Lost MDD Timeout
    Jul 6 04:29:11 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
    Jul 6 09:24:55 2017 Warning (5) Lost MDD Timeout
    Jul 6 09:43:52 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
    • vkdelta's avatar
      vkdelta
      can you please post your powet table as well from the connection page? thank you.
      • AlistairPhoenix's avatar
        AlistairPhoenix
        Downstream Bonded Channels
        Channel Lock Status Modulation Channel ID Frequency       Power       SNR Correctables UnCorrectables
        1        Locked QAM 256                  1            567000000 Hz  8.7 dBmV  35.5 dB            24 686
        2        Locked QAM 256                  2            573000000 Hz  8.4 dBmV  35.5 dB            19 544
        3        Locked QAM 256                  3            579000000 Hz  8.2 dBmV  35.4 dB              6 541
        4        Locked QAM 256                  4            585000000 Hz  8.2 dBmV  35.4 dB            19 733
        5        Locked QAM 256                  5            591000000 Hz  8.5 dBmV  35.5 dB            29 615
        6        Locked QAM 256                  6            597000000 Hz  9.0 dBmV  35.5 dB            26 702
        7        Locked QAM 256                  7            603000000 Hz  9.3 dBmV  35.9 dB            31 651
        8        Locked QAM 256                  8            609000000 Hz  9.7 dBmV  36.1 dB            33 611
        Upstream Bonded Channels
        Channel Lock Status US Channel Type Channel ID Symbol Rate      Frequency       Power
        1        Locked                     ATDMA            44        2560 Ksym/sec     21400000 Hz  39.5 dBmV
        2        Locked                     ATDMA            43        2560 Ksym/sec     25000000 Hz  39.8 dBmV
        3        Locked                     ATDMA            42        5120 Ksym/sec     30700000 Hz  40.5 dBmV
        4        Locked                     ATDMA            41        5120 Ksym/sec     37500000 Hz  41.3 dBmV
