nicosia2013
Jul 09, 2016Aspirant
My Netgear C6300 wifi modem gives me only 75mbs when i use wifi and 300 when i use ethernet.
My new Netgear C6300 wifi modem gives me only 75mbs when i use wifi and 300 when i use ethernet cable. I have TWC 300 mbs conection. I dont know why i get only 60 - 75 mbs in wifi even being clo...
VE6CGX
Jul 09, 2016Master
Two things, on which band? Are you using -ac mode WiFi card? Always WiFi speed is less than that of wired connection but your case is too much different. Did you set up the wireless configuration properly?
- nicosia2013Jul 09, 2016Aspirant
hi ve6cgx and thanks in advance.
im very bad in computers matters.
i have conected to my wifi modem my mac book
i dont know which band iam using, how can i get that info?
i didnt set up or change anything, just conected and called TWC and they activated my modem.
Should i change the wirelles configuration? i notice that i have a 5ghz wireless too, should i use that one?
thank you.
- VE6CGXJul 09, 2016Master
Usually having different SSID between 2.4GHz and 5GHz band is good idea.
so whats your advice? what you think i can do to get at least 200mbs on wifi ??
