nicosia2013
Jul 09, 2016Aspirant
My Netgear C6300 wifi modem gives me only 75mbs when i use wifi and 300 when i use ethernet.
My new Netgear C6300 wifi modem gives me only 75mbs when i use wifi and 300 when i use ethernet cable. I have TWC 300 mbs conection. I dont know why i get only 60 - 75 mbs in wifi even being clo...
VE6CGX
Jul 09, 2016Master
Two things, on which band? Are you using -ac mode WiFi card? Always WiFi speed is less than that of wired connection but your case is too much different. Did you set up the wireless configuration properly?
nicosia2013
hi ve6cgx and thanks in advance.
im very bad in computers matters.
i have conected to my wifi modem my mac book
i dont know which band iam using, how can i get that info?
i didnt set up or change anything, just conected and called TWC and they activated my modem.
Should i change the wirelles configuration? i notice that i have a 5ghz wireless too, should i use that one?
thank you.
- VE6CGXJul 09, 2016Master
Usually having different SSID between 2.4GHz and 5GHz band is good idea.
- nicosia2013Jul 09, 2016Aspirant
so whats your advice? what you think i can do to get at least 200mbs on wifi ??
I'd use 5GHz band first of all if possible re: range. And better have -ac mode capable WiFi card in your laptop or PC.
Then configure 5GHz wireless band on the router, assuming WMM is already enabled; select higher channel like 149 or 153,
select WPA2-AES security protocol, select bandwidth to 40MHz, select speed to max value like upto xxxx. And see what happens..
