nicosia2013
Jul 09, 2016Aspirant
My Netgear C6300 wifi modem gives me only 75mbs when i use wifi and 300 when i use ethernet.
My new Netgear C6300 wifi modem gives me only 75mbs when i use wifi and 300 when i use ethernet cable. I have TWC 300 mbs conection. I dont know why i get only 60 - 75 mbs in wifi even being clo...
nicosia2013
hi ve6cgx and thanks in advance.
im very bad in computers matters.
i have conected to my wifi modem my mac book
i dont know which band iam using, how can i get that info?
i didnt set up or change anything, just conected and called TWC and they activated my modem.
Should i change the wirelles configuration? i notice that i have a 5ghz wireless too, should i use that one?
thank you.
VE6CGX
Jul 09, 2016Master
Usually having different SSID between 2.4GHz and 5GHz band is good idea.
- nicosia2013Jul 09, 2016Aspirant
so whats your advice? what you think i can do to get at least 200mbs on wifi ??
- VE6CGXJul 09, 2016Master
I'd use 5GHz band first of all if possible re: range. And better have -ac mode capable WiFi card in your laptop or PC.
Then configure 5GHz wireless band on the router, assuming WMM is already enabled; select higher channel like 149 or 153,
select WPA2-AES security protocol, select bandwidth to 40MHz, select speed to max value like upto xxxx. And see what happens..
