nicosia2013
Jul 09, 2016Aspirant
My Netgear C6300 wifi modem gives me only 75mbs when i use wifi and 300 when i use ethernet.
My new Netgear C6300 wifi modem gives me only 75mbs when i use wifi and 300 when i use ethernet cable. I have TWC 300 mbs conection. I dont know why i get only 60 - 75 mbs in wifi even being clo...
Moleary619
I was thinking that was the case, but I know it can go up to 150mbps Link speed at least but its stuck at 65 now, any way to change that back?
VE6CGX
Jul 09, 2016Master
That is max. theoritical speed. In real life if one can get ~2/3 of wired connection speed, that is very good. It depends signal strength, how you configure the wireless on the router. For good wirless connection. I'd say signal strength of 60dbm or better(lower number). Actually the value indicates attenuation. So high number is bad(weaker signal).Also noise, adjacent channel interference(specially on crowded 2.4GHz band), etc. also some additional factors.
Any radio communication is 2 way. Router TX >>>> device RX
Device TX >>>> router RX here usually device end is weaker link but folks tent to think only about router
forgetting this fact. Router has bigger antenna produces max(legally) 100mW TX power but laptops have poor antenna imbedded in the frame,
low flea TX power ouput, etc. Even tho router signal radiation p[attern is omni directional it is not really so due to surroundings. Not to close to walls, facing device braad sided of router, playing with antenna stick angles,etc. Wave length of router signal is very short, so moving router even a foot to this or that way often yields improved signal level at particular device end. By experiemnting I know where is the best spot for my router's location in my house...That is upstairs loft where my work station and HAM radio shack are located.
