Aktright's avatar
Aktright
My upload speed is very low
This started last week and was fixed by calling my ISP which they reset something on their end. Now a week later, I'm having the same problems this time them resetting on their end only temporarly fixed it and now I'm back to very low upload speeds. I usually get 20mbps and now I fluctuate from .05 - 3mbps. They said everything is good on their end twice and then asked if my modem is the problem. I've already factory resetted my modem to see if that was the problem and still no so I'm trying to rule out if my modem is the problem. I checked the cable connection and uploaded it here to see if any of you could help me out if the modem is the problem.
  • plemans's avatar
    You're cable connections signal strength is very high. Optimal is -7.5dbmv to 7.5dbmv.  You're hitting 13dbmv.
    Its not causing any downstream errors and your upstream power looks fine but its still a bit concerning to be running that hot.
    Do you have your modem logs?
    • Aktright's avatar
      Aktright
      I do. I'll add it as an attachment here. Do you think it's the modem or probably and issue that an Xfinity tech needs to fix when he gets here tomorrow?
      • plemans's avatar
        The tech needs to check the line. Between your high power levels and your logs, you have power issues/signal issues.
