jonathanpmast
Aug 24, 2015Aspirant
N300 (C3000) in Bridge Mode with TWC
The Netgear C3000 seems to have an underpowered router and Wifi radio compared to dedicated devices. I have a separate router that I can pair up with the modem that can fit the job perfectly. I wou...
- Jun 01, 2016
After installing the Mac VPN passthru profile I was able to place the Netgear C3000 in bridge mode and it maintained the bridge mode thru a couple reboots. After which I was able to connect and configure a TP-Link TL-WR841N wifi router. Doing this also increased my wifi speed from 28 to 60Mbs on the TP-Link router.
DarrenM
Aug 28, 2015Sr. NETGEAR Moderator
Hello Jonathanpmast
This isnt a Firmware issue but a issue with the configuration file pushed by the isp that is not allowing the device to be put into bridge mode.
DarrrenM
jonathanpmast
Aug 28, 2015Aspirant
Thanks Darren,
Has anyone communicated the issue from Netgear to TWC?
- DarrenMAug 28, 2015Sr. NETGEAR Moderator
Hello jonathanpmast
Yes I did communicate this to a higher level and they are investigating the issue.
DarrenM
- jonathanpmastAug 28, 2015Aspirant
Thanks Darren, please keep me updated.
- jonathanpmastOct 20, 2015Aspirant
Darren,
Do you have any updates regarding this issue? It has been nearly two months.Thanks,
Jonathan
- DarrenMOct 20, 2015Sr. NETGEAR Moderator
Hello jonathanpmast
I do know that TWC should be pushing new firmware to the modems soon so keep checking the firmware and if it changes try to swap it to bridge mode. I dont know the exact time on the firmware I know comcast has already pushed there firmware update but not TWC yet.
DarrenM
