ItzBroken
Jun 24, 2016Aspirant
N300 C3000 Wifi Stops Working / Connecting
Hi my Cable Modem / Router N300 C-3000 has a really annoying issue where after about 10 mins it stops communicating with all my devices. I called the cable company who said my signal was great (TWC) a...
DarrenM
Jul 05, 2016Sr. NETGEAR Moderator
Hello ItzBroken
I have sent you a private message
DarrenM
ericpeters0n
Oct 03, 2016Aspirant
Same problem, seems common.
Netgear support: Can you suggest a fix?
- DarrenMOct 05, 2016Sr. NETGEAR Moderator
Hello ericpeters0n
Have you tried to adjust the wireless channel or lowering the wireless speed?
DarrenM
