Mattst
Jan 11, 2017Aspirant
N450 CG3000Dv2 dropping wired and wireless connection repeatedly
A few days ago I started losing my connection from my N450 CG3000Dv2 modem/router. This occurs on both a hard-wired (gigabit) connection to the router and on other devices connected wirelessly. I c...
DarrenM
Jan 13, 2017Sr. NETGEAR Moderator
Hello Mattst
You could post the logs when it happens you can find them in the settings under Maintenance and then event log. This may tell us what is happening.
DarrenM
Mattst
Jan 13, 2017Aspirant
Thanks. Here's the log:
Time Priority Description
2017-01-12, 01:33:52.0 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=my:ff:ff:ff:ff:my;CMTS-MAC=00:01:02:02:03:03;CM-QOS=1.0;CM-VER=3.0;
2017-01-12, 01:33:23.0 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=my:ff:ff:ff:ff:my;CMTS-MAC=00:01:02:02:03:03;CM-QOS=1.0;CM-VER=3.0;
2017-01-12, 01:30:34.0 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=my:ff:ff:ff:ff:my;CMTS-MAC=00:01:02:02:03:03;CM-QOS=1.0;CM-VER=3.0;
2017-01-12, 01:25:45.0 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=my:ff:ff:ff:ff:my;CMTS-MAC=00:01:02:02:03:03;CM-QOS=1.1;CM-VER=3.0;
2017-01-12, 01:23:42.0 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=my:ff:ff:ff:ff:my;CMTS-MAC=00:01:02:02:03:03;CM-QOS=1.1;CM-VER=3.0;
2017-01-12, 01:21:55.0 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=my:ff:ff:ff:ff:my;CMTS-MAC=00:01:02:02:03:03;CM-QOS=1.1;CM-VER=3.0;
2017-01-12, 01:21:49.0 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=my:ff:ff:ff:ff:my;CMTS-MAC=00:01:02:02:03:03;CM-QOS=1.1;CM-VER=3.0;
Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=my:ff:ff:ff:ff:my;CMTS-MAC=00:01:02:02:03:03;CM-QOS=1.0;CM-VER=3.0;
Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6
Time Not Established Notice (6) WiFi Interface [wl0] set to Channel 3 (Side-Band Channel:N/A) - Reason:INIT
