mdezrin
Jan 22, 2021Aspirant
Need help selecting Xfinity cable modem
I need help selecting an Xfinity compaible cable modem for a small home office that supports 4-5 people. They have 300mbps. They will add a mesh WiFi for device connectivity. There are about 5 lap...
Jan 22, 2021Guru - Experienced User
I'd recommend any of the docsis 3.1 devices.
Like the CM1000, CM1100, CM1200, or CM2000
They're all gigabit capable and docsis 3.1.
We're seeing more ISP's requiring docsis 3.1 modems for lower speed tiers so the little extra is worth is for making sure you're hitting minumum requirements for your speed levels.
Plus I've used them all but the CM1200 on xfinity and they've worked great.
mdezrin
Do you forsee any compatibility issues with any of the usual mesh vendors - Linksys, TP-Link, Asus or Google?
If I add voice into the equation, do you have any other suggestions?
Have you used any non-netgear that you'd recommend? Motorola or Arris?
Thanks.
- FURRYe38Jan 22, 2021Guru - Experienced User
Seen no compatibily with NG, D-Link, ASUS or NetDuma routers. There isn't any compatibility issues with WiFi routers, they either work or they don't. If they don't it's usually a cable or HW issue at either the modem or wifi router. Otherwise, most wifi routers work fine.
