mdezrin
Jan 22, 2021Aspirant
Need help selecting Xfinity cable modem
I need help selecting an Xfinity compaible cable modem for a small home office that supports 4-5 people. They have 300mbps. They will add a mesh WiFi for device connectivity. There are about 5 lap...
mdezrin
Do you forsee any compatibility issues with any of the usual mesh vendors - Linksys, TP-Link, Asus or Google?
If I add voice into the equation, do you have any other suggestions?
Have you used any non-netgear that you'd recommend? Motorola or Arris?
Thanks.
Jan 22, 2021Guru - Experienced User
Seen no compatibily with NG, D-Link, ASUS or NetDuma routers. There isn't any compatibility issues with WiFi routers, they either work or they don't. If they don't it's usually a cable or HW issue at either the modem or wifi router. Otherwise, most wifi routers work fine.
