  • plemans's avatar
    what errors are you getting?
    Its tough to help without info/photos/better descriptions of what you're putting in and attempting to do
    • oldvern's avatar
      oldvern
      trying to add this device , A = these are the numbers i put in . get error IP address not in lan . invalid server .I guess I dont know what they are asking for .
      • plemans's avatar
        You're right. its not in your lan.
        In your one photo, you're setting your port forwarding settings for 192.168.51.1
        But the next photo is showing your router's lan range is in the .0 range (192.168.0.***)
  • michaelkenward's avatar
    michaelkenward
    oldvern wrote:
    I need to open some ports to allow a wifi device to commutate with manufacturer .
    It  might be easier if you provided a few more details about that.
    Explain the problem you want to fix rather than what you have been told might be the solution .
    What is this wifi device and why does it need messing around with ports?
    That is not a typical requirement.
    You never know, someone may have turned up here before with the same challenge.
