samuelatlas's avatar
samuelatlas
Netgear C3700 Modem/Router
I cant telnet into my router is there some thing i doing wrong?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Samuelatlas
    Can you give some more detail on the steps you have done and what issues you get when trying to telnet.
    DarrenM
    • samuelatlas's avatar
      samuelatlas
      ok i have putty installed i type in my ip address and choose telnet. i get "network error :connection timed out."
      • DarrenM's avatar
        DarrenM
        Hello samuelatlas
        Have you gone to 192.168.0.1/debug.htm to enable telnet.
        DarrenM
      samuelatlas
      I figured it out the router i have does not support telnet. I should have goten the more expensive one. according to net gear I need the business class router not the home one.
