BossinSauce
Nov 15, 2016Aspirant
Netgear C7000 Nighthawk Modem/Router Combo losing connection
I recently looked into logs and event logs and maybe have found the issue but I don't know how to resolve them. I'm in need of help and what i can do to fix it. My product is out of warranty and really cant afford to buy a new one even though its working fine. I will post logs below and please help me. Event Logs and Logs Below!
Event Logs:
| 1970-1-1, 00:00:38 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:38:d3:20;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:46 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=40:5d:82:38:d3:20;CMTS-MAC=00:01:5c:88:04:49;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:37 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:38:d3:20;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:42 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=40:5d:82:38:d3:20;CMTS-MAC=00:01:5c:88:04:49;CM-QOS=1.0;CM-VER=3.0; |
| 2016-10-15, 02:04:58 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=40:5d:82:38:d3:20;CMTS-MAC=00:01:5c:88:04:49;CM-QOS=1.1;CM-VER=3.0; |
| 2016-10-19, 00:51:18 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=40:5d:82:38:d3:20;CMTS-MAC=00:01:5c:88:04:49;CM-QOS=1.1;CM-VER=3.0; |
| 2016-10-20, 18:16:05 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=40:5d:82:38:d3:20;CMTS-MAC=00:01:5c:88:04:49;CM-QOS=1.1;CM-VER=3.0; |
| 2016-10-23, 02:29:20 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=40:5d:82:38:d3:20;CMTS-MAC=00:01:5c:88:04:49;CM-QOS=1.1;CM-VER=3.0; |
| 2016-10-25, 04:09:06 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=40:5d:82:38:d3:20;CMTS-MAC=00:01:5c:88:04:49;CM-QOS=1.1;CM-VER=3.0; |
| 2016-10-31, 17:56:49 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=40:5d:82:38:d3:20;CMTS-MAC=00:01:5c:88:04:49;CM-QOS=1.1;CM-VER=3.0; |
| 2016-11-1, 20:31:55 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=40:5d:82:38:d3:20;CMTS-MAC=00:01:5c:88:04:49;CM-QOS=1.1;CM-VER=3.0; |
| 2016-11-6, 02:47:17 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=40:5d:82:38:d3:20;CMTS-MAC=00:01:5c:88:04:49;CM-QOS=1.1;CM-VER=3.0; |
| 1970-1-1, 00:00:43 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=40:5d:82:38:d3:20;CMTS-MAC=00:01:5c:88:04:49;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:02:04 | Critical (3) | TFTP failed - Request sent - No Response;CM-MAC=40:5d:82:38:d3:20;CMTS-MAC=00:01:5c:88:04:49;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:02:04 | Critical (3) | TFTP Request Retries exceeded, CM unable to register |
| 1970-1-1, 00:02:16 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=40:5d:82:38:d3:20;CMTS-MAC=00:01:5c:88:04:49;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:40 | Notice (6) | WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INIT |
| 1970-1-1, 00:00:40 | Notice (6) | WiFi Interface [wl1] set to Channel 153 (Side-Band Channel:N/A) - Reason:INIT |
| 1970-1-1, 00:00:47 | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
| 2016-11-15, 06:11:06 | Notice (6) | WiFi Interface [wl0] set to Channel 1 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2016-11-15, 06:26:14 | Notice (6) | WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2016-11-15, 07:14:05 | Notice (6) | WiFi Interface [wl0] set to Channel 6 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2016-11-15, 07:29:22 | Notice (6) | WiFi Interface [wl0] set to Channel 1 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2016-11-15, 08:50:48 | Notice (6) | WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2016-11-15, 09:05:55 | Notice (6) | WiFi Interface [wl0] set to Channel 1 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2016-11-15, 09:23:13 | Notice (6) | WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2016-11-15, 10:11:56 | Notice (6) | WiFi Interface [wl0] set to Channel 1 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2016-11-15, 10:28:40 | Notice (6) | WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2016-11-15, 10:43:54 | Notice (6) | WiFi Interface [wl0] set to Channel 1 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2016-11-15, 12:01:24 | Notice (6) | WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2016-11-15, 12:16:30 | Notice (6) | WiFi Interface [wl0] set to Channel 1 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2016-11-15, 13:01:44 | Notice (6) | WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2016-11-15, 16:04:29 | Notice (6) | WiFi Interface [wl0] set to Channel 1 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
- BossinSauceAspirant
Logs: (goes on and on but had to resize due to restrictions
[DHCP IP: 192.168.0.13] to MAC address 48:5d:60:3c:c3:43 1 Tue Nov 15 17:51:15 2016 0.0.0.0:0 0.0.0.0:0 [DoS attack: Illegal Fragments] from 130.0.3.176, port 0 1 Tue Nov 15 17:51:12 2016 73.75.242.34:0 130.0.3.176:0 [DoS attack: Teardrop or derivative] from 130.0.3.176, port 0 3 Tue Nov 15 17:51:08 2016 73.75.242.34:0 130.0.3.176:0 [DHCP IP: 192.168.0.13] to MAC address 48:5d:60:3c:c3:43 1 Tue Nov 15 17:50:37 2016 0.0.0.0:0 0.0.0.0:0 [DoS attack: Teardrop or derivative] from 130.0.3.176, port 0 2 Tue Nov 15 17:50:36 2016 73.75.242.34:0 130.0.3.176:0 [DoS attack: Illegal Fragments] from 130.0.3.176, port 0 1 Tue Nov 15 17:49:49 2016 73.75.242.34:0 130.0.3.176:0 [DoS attack: Ping Of Death] from 130.0.3.176, port 0 2 Tue Nov 15 17:49:02 2016 73.75.242.34:0 130.0.3.176:0 [DoS attack: Teardrop or derivative] from 130.0.3.176, port 0 1 Tue Nov 15 17:47:49 2016 73.75.242.34:0 130.0.3.176:0 [DHCP IP: 192.168.0.13] to MAC address 48:5d:60:3c:c3:43 1 Tue Nov 15 17:33:46 2016 0.0.0.0:0 0.0.0.0:0 [DoS attack: Illegal Fragments] from 130.0.3.176, port 0 2 Tue Nov 15 17:32:57 2016 73.75.242.34:0 130.0.3.176:0 [DHCP IP: 192.168.0.13] to MAC address 48:5d:60:3c:c3:43 1 Tue Nov 15 17:31:41 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.13] to MAC address 48:5d:60:3c:c3:43 1 Tue Nov 15 17:26:00 2016 0.0.0.0:0 0.0.0.0:0 [DoS attack: Illegal Fragments] from 130.0.3.176, port 0 1 Tue Nov 15 17:25:30 2016 73.75.242.34:0 130.0.3.176:0 [DHCP IP: 192.168.0.13] to MAC address 48:5d:60:3c:c3:43 1 Tue Nov 15 17:24:55 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.13] to MAC address 48:5d:60:3c:c3:43 1 Tue Nov 15 17:09:39 2016 0.0.0.0:0 0.0.0.0:0 [DoS attack: Ping Of Death] from 130.0.3.176, port 0 7 Tue Nov 15 17:07:10 2016 73.75.242.34:0 130.0.3.176:0 [DoS attack: Teardrop or derivative] from 130.0.3.176, port 0 2 Tue Nov 15 16:57:04 2016 73.75.242.34:0 130.0.3.176:0 [DoS attack: Ping Of Death] from 130.0.3.176, port 0 5 Tue Nov 15 16:55:53 2016 73.75.242.34:0 130.0.3.176:0 [DoS attack: Illegal Fragments] from 130.0.3.176, port 0 1 Tue Nov 15 16:49:15 2016 73.75.242.34:0 130.0.3.176:0 [DoS attack: Ping Of Death] from 130.0.3.176, port 0 8 Tue Nov 15 16:49:08 2016 73.75.242.34:0 130.0.3.176:0 [DoS attack: Teardrop or derivative] from 130.0.3.176, port 0 1 Tue Nov 15 16:46:34 2016 73.75.242.34:0 130.0.3.176:0 [DoS attack: Illegal Fragments] from 130.0.3.176, port 0 3 Tue Nov 15 16:46:34 2016 73.75.242.34:0 130.0.3.176:0 [DoS attack: Teardrop or derivative] from 130.0.3.176, port 0 1 Tue Nov 15 16:45:43 2016 73.75.242.34:0 130.0.3.176:0 [DoS attack: Ping Of Death] from 130.0.3.176, port 0 1 Tue Nov 15 16:45:43 2016 73.75.242.34:0 130.0.3.176:0 [DoS attack: Teardrop or derivative] from 130.0.3.176, port 0 1 Tue Nov 15 16:45:43 2016 73.75.242.34:0 130.0.3.176:0 [DoS attack: Illegal Fragments] from 130.0.3.176, port 0 1 Tue Nov 15 16:45:43 2016 73.75.242.34:0 130.0.3.176:0 [DoS attack: Teardrop or derivative] from 130.0.3.176, port 0 1 Tue Nov 15 16:45:42 2016 73.75.242.34:0 130.0.3.176:0 [DoS attack: Ping Of Death] from 130.0.3.176, port 0 5 Tue Nov 15 16:45:42 2016 73.75.242.34:0 130.0.3.176:0 [DoS attack: Teardrop or derivative] from 130.0.3.176, port 0 2 Tue Nov 15 16:45:41 2016 73.75.242.34:0 130.0.3.176:0 [DoS attack: Ping Of Death] from 130.0.3.176, port 0 2 Tue Nov 15 16:45:41 2016 73.75.242.34:0 130.0.3.176:0 [DoS attack: Teardrop or derivative] from 130.0.3.176, port 0 1 Tue Nov 15 16:45:02 2016 73.75.242.34:0 130.0.3.176:0 [DHCP IP: 192.168.0.14] to MAC address a4:b8:05:67:73:12 1 Tue Nov 15 16:39:41 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.17] to MAC address 88:71:e5:a6:e5:63 1 Tue Nov 15 07:56:03 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.13] to MAC address 48:5d:60:3c:c3:43 1 Tue Nov 15 05:26:14 2016 0.0.0.0:0 0.0.0.0:0 [DoS attack: Ping Of Death] from 130.0.3.176, port 0 3 Tue Nov 15 05:25:10 2016 120.234.61.162:0 130.0.3.176:0 [DHCP IP: 192.168.0.15] to MAC address 5c:dc:96:ba:7d:46 1 Tue Nov 15 04:19:57 2016 0.0.0.0:0 0.0.0.0:0 [DoS attack: Ping Of Death] from 130.0.3.176, port 0 1 Tue Nov 15 01:21:45 2016 120.234.61.162:0 130.0.3.176:0 [DoS attack: Ping Of Death] from 130.0.3.176, port 0 1 Tue Nov 15 00:51:59 2016 64.48.155.244:0 130.0.3.176:0 [DoS attack: Teardrop or derivative] from 130.0.3.176, port 0 1 Tue Nov 15 00:09:04 2016 120.234.61.162:0 130.0.3.176:0 [DoS attack: Illegal Fragments] from 130.0.3.176, port 0 1 Mon Nov 14 22:02:44 2016 64.48.155.244:0 130.0.3.176:0 [DoS attack: Teardrop or derivative] from 130.0.3.176, port 0 1 Mon Nov 14 22:02:43 2016 64.48.155.244:0 130.0.3.176:0 [DoS attack: Ping Of Death] from 130.0.3.176, port 0 2 Mon Nov 14 22:02:43 2016 64.48.155.244:0 130.0.3.176:0 [DoS attack: Illegal Fragments] from 130.0.3.176, port 0 1 Mon Nov 14 22:02:43 2016 64.48.155.244:0 130.0.3.176:0 [DoS attack: Teardrop or derivative] from 130.0.3.176, port 0 1 Mon Nov 14 22:02:43 2016 64.48.155.244:0 130.0.3.176:0 [DoS attack: Ping Of Death] from 130.0.3.176, port 0 1 Mon Nov 14 22:02:43 2016 64.48.155.244:0 130.0.3.176:0 - DarrenMSr. NETGEAR Moderator
Hello BossinSauce
Sometimes DOS attacks are not always a DOS attack it could be some site you use or program you use that looks like a DOS attack you would have to look up the 130.0.3.176 address and find where it is coming from to see if its bad or not.
DarrenM
- BossinSauceAspirantI've had some issues today and not seeing any event logs but still seeing these DOS attempts the target up address isn't even mine it points to another country and the source is also another country. Not sure on why/how this could be happening. Could it be the router malfunctioning? It happens when no one is here and all devices are shut down so I don't think it's a program and no Ethernet is plugged in.
Hello BossinSauce
It could be the modem I would contact your ISP and see if they are able to switch your IP address and then if its still happening we will know its something going on the local network not someone attacking your Ip address.
DarrenM
