clifftoboggan's avatar
Aug 02, 2019
Netgear C7000v2 All LAN Links down, only one can be active
Hi All
So recently I ran into some issues with my C7000v2. Only one LAN Link (in the back of the router) can be active at a time. All cables will work, as I have tried several, but only one can be used, which is the cable I am running via powerline adapter to my laptop. My Playstation 4 or Xbox One will not connect via Ethernet. On the Internet Port page in the Genie the image attached is what will show.
As an example, if a cable is run to my playstation, it will work, but another cable run at the same time to my PC will not work.
I have no idea what the issue is, I have power cycled, factory reset, run a cable loop that showed both lights on, everything I know to do. Any help?
  • FURRYe38's avatar
    Please post about this over in the cable modem forum:
    https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
    Good Luck.
    clifftoboggan wrote:
    Hi All
    • antinode's avatar
      antinode
      Guru
         Visit http://netgear.com/support , put in your model number, and look
      for Documentation.  Get the User Manual.  Read.  Look for "Router Mode",
      as in: ADVANCED > Administration > Router Mode.
         You want "Yes".
