stevelnancyl
Nov 28, 2023Aspirant
Netgear C7000v2 USB Not showing NAS (Network Attached Storage)
I have a c7000v2 Netgear router/modem. I am trying to install a NAS to the USB port located at the top of the router. I have a 64 Gig Flash drive plugged in. When I log into the router, the Genie...
michaelkenward
Nov 29, 2023Guru - Experienced User
stevelnancyl wrote:
I cannot find this device on my network although with windows I can see \\readyshare available under NETWORKS. However clicking on it shows nothing and I cannot copy anything to it.
The clue may be in the "Windows" bit. Nothing to do with your modem/router or ReadySHARE
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
Here's where to look in Windows 11:
- Settings
- Apps
- Optional Features
- More Windows features
If you have other issues specific to with your cable modem/router try here:
