csandoval1994
May 13, 2019Aspirant
Netgear C7800 Dual Band Issues
I have a Netgear C7800 that I bought about a tad bit over a year ago. Long story short, the dual-band modem router has had a major issue sometime mid lifetime of ownership. The 2.4GHz connection can be broadcasted but FAILS at giving off an internet connection to any device that connects to it. No matter what device I try with, no internet, however; the 5GHz conncetion works totally fine and I am able to do what I would normally do with it. Although the 5GHz connection works and the 2.4GHz DOES NOT WORK, any and all older devices that are unable to connect to the new 5GHz are now internet-less. Now for the main question(s) I am here to ask:
1) Why is this happening?
2) How can I resolve this issue?
3) Is my product now single-band for its remainder of life?
Little more info…
Now to get rid of the common comments and things that I could do/should have done. Yes I have talked with my ISP multiple times over multiple phone calls lasting over sixty minutes each and getting nothing but "talk to Netgear". Yes I have talked to Netgear about the dilemma and they have told me on a few phone calls to "talk to your ISP, it's their problem, not our product". Yes I have researched and have done probably a little of everything from as simple as turn off and then back on, unplug, wait "ten" seconds and plug back in, factory reset, firmware update is impossible to do, unless pushed via my ISP and my ISP alone. I have no power in being able to downgrade to a previous version where it once worked. ISP is incapable of downgrading my firmware since all firmware updates are pushed via ISP and can not be reverted back. I have also searched through the community forums here and have found "solutions" to other people's questions about their troublesome product within the same issue on my product and those solutions do not give me any positive results.
…no so little info I suppose
So, for any single person who has a single clue as to why this is happening and how to resolve it, I am all ears and hopefull you can salvage this piece of plastic to give the old plastic some internet. Even though small possible solutions like mentioned have been done, I will attempt again, but I recommend to not make waste of your time if that is what you offer to me as a possibility. I feel like everything has been attempted and no luck. I thank you ahead of time for anyone who knows how to get to the bottom of this and get it up and working like new. I also thank the people in advance to offering possiblities on solutions or any aid in my quest to get a fix for this modem router.
Thank you again and may we once again allow these old devices to see the internet once more.
Thank you
***Rant, Unneccasry Read(but goes out to you customer service managment who cares about this)***
All products I have ever owned by Netgear have been a collasal let down from being given to me to being purchased. The Netgear "specialist" support is another let down due to my previous year having spent little days out of it to try and get a fix yet failing each attempt with no help other than mentioned "call your ISP. Their fault not ours. We have your money. Don't care. Thanks." (I jest in the last few out of this small enraging convenience I have built up for quite some time). In hopes of fixing to sell away and not giving someone the short end of the stick on the product. Never purchasing another Netgear product. Will decline any and all netgear products. ♥☺
Any Wifi Neighbors near by? If so, how many?Disable WPA security on 2.4ghz temporarily and then try to connect a device to the 2.4Ghz radio. Does it get internet at all?
Has a factory reset and setup from scratch been performed?
- csandoval1994Aspirant
Firmware is the latest version and before you may possibly ask, no I can not downgrade to a previous version since ISP will not do so and modem offers no way of manually doing so.
Channels have been changed to every single one possible and I have already checked what channels my neighbors are using with a third party application. As for how many neighbors I have around with a wifi signal would be about 3-4 depending in area of my house but from where my modem is set up, only three are available excluding mine.
Attempted to disable WPA and had no success.
As mentioned in my post, a device can connect to the 2.4GHz connection, but the band does not give off any internet what so ever. For a deeper clarification: phones, tablets, any device that connects, once password is entered, all devices will give an error of no internet connection.
Factory reset has been done multiple times and the same result is give. It returns to the same old "no internet connection" on any device that connects to it.
Appreciate the help and questions.- FURRYe38Guru - Experienced User
Yes we know you can't downgrade modems nor upgrade them. ISPs do that.
Sounds like this unit needs to be RMAd is all. I'm sure NG can help you out:
https://www.netgear.com/mynetgear/registration/login.aspx
If anything, you can change the C7800 from gateway router mode to modem mode only and still use the modem portion of the C7800. It's how I'm using mine currently. Get you self a external router. The R7800 would match up well. Something to reivew. I would ask for an RMA though.
Good Luck.
