bodybag's avatar
bodybag
netgear CM1000 MODEM-Nighthawk R7800 router losing wifi signal
we have a quad level home, 2500 sqft .we just upgraded our cable to 600mbps so we upgraded our modem to a netgear cm1000. we have a netgear R7800 nighthawk router. they are on the second level with the modem, tv, and roku box. they are all about 8 ft. apart from each other. we have 2 desktops, 2 laptops, roku, a wireless ADT alarm system w/ doorbell camera, 2 motion sensors, 2 smoke detectors, 2 carbon detectors, with that being said, the router drops signal half dozen times or better /week. do I need to upgrade the router ? Model: R7800|Nighthawk X4S AC2600 Wifi Router
  • michaelkenward's avatar
    michaelkenward
    Is this possibly down to the location of these devices? Wifi signals have a limited range.
    When it comes to connecting things like smart TVs, I prefer Powerline Ethernet. Easier to set up than wifi and less sensitive to wifi interference and general flakiness.
    Did you reset the R7800 when you changed the modem? You don't want it remembering settings that it may have inherited from an older modem.
    • bodybag's avatar
      bodybag
      The router, modem, and tv/roku box are all within 8-10 ft of each other on same floor. Router has been reset. Wasnt sure if the router was struggling to handle everything or not.
      • plemans's avatar
        The R7800 is a pretty solid router.
        What firmware do you have on it?
        is it 2.4ghz that's having issues? 5ghz?
        Make sure your streaming/gaming devices are on the 5ghz.
