DeclanMiner2005's avatar
Aug 10, 2024
Netgear CM1000 No power light but all lights except upstream light orange and upstream light red
The model is I believe a CM1000v2
And this I guessed maybe this is a code? (maybe red is 0 or 1 and amber is 1 or 0?)
So, I guessed that maybe it was a error code 1011 or 0100??
I am trying to use it with with my Netgear Nighthawk AC1750 R6700v3
I tried the 15 second RESET button trick, but no luck.
Can anyone help me here??? If not I will buy another different modem I guess.
  • FURRYe38's avatar
    Is this with the ISP coax cable disconnected from the modem?
    Try a different power supply that has same volts and amps?
    • DeclanMiner2005's avatar
      DeclanMiner2005
      No, everything is original except no ISP is connected yet. The power adapter and everything is the same.
      • FURRYe38's avatar
        Disconnect the ISP coax cable then factory reset the modem.
        Try a different power supply that has same volts and amps...
