johnalameda's avatar
johnalameda
Netgear CM1100 V2.01.02 - Listening on both 192.168.0.1 and 192.168.100.1
Hi, I have a Netgear CM1100 using firmware version V2.01.02.  I did a routine scan on my network using NMAP and noticed that the modem is listening on both 192.168.0.1 and 192.168.100.1.  I know that 192.168.100.1 is the admin portal.  I am able to log into it successfully and see all the modem stats.
However, I am confused on what 192.168.0.1 is.  Is it expected that my modem would be using this IP address as well?  I am directly connected to the modem so there is no external router or anything like that.  When I use the browser to navigate to http://192.168.0.1, I see a login prompt but none of my user/password or the default user/password work for this.
In case it helps, here is what I get back from NMAP.
Nmap scan report for 192.168.0.1
Host is up (0.0022s latency).
Not shown: 998 filtered tcp ports (no-response)
PORT STATE SERVICE
80/tcp open http
443/tcp closed https
Nmap scan report for 192.168.100.1
Host is up (0.0077s latency).
Not shown: 998 closed tcp ports (reset)
PORT STATE SERVICE
80/tcp open http
8080/tcp open http-proxy
Thanks!
  • FURRYe38's avatar
    Was NOT able to access the modems web page at 192.168.0.1 whatsoever.
  • FURRYe38's avatar
    And this is with out a external router connected to the modem?
    • johnalameda's avatar
      johnalameda
      Yes that's correct. I am directly connected to the modem.  There is no external router hooked up to the modem.
      • FURRYe38's avatar
        Are both accessible if the external router is connected and the router is set for .0.1? I presume that should be accessible then. The .100.1 should be though.
