wkw62
Sep 20, 2017Aspirant
Netgear CM500 vs CM500 NAS, What's the difference?
Netgear CM500 vs CM500 NAS, What's the difference? If there IS a difference, will either work with Time Warner Cable ISP?
Thanks for the reply.
I assumed they are the same (the spec sheets were identical).
I don't know why companies give different model #s but don't tell us the diff, if any !
Thanks again, and I really appreciate the email response (so I don't have to keep checking the forum to get an answer - the reason I don't usually use forums).
- I believe NAS is for North American markets.
- vkdeltaNETGEAR Employee Retired
they are both same.
CM500 = CM500-100NAS = CM500-1AZNAS
there might minor packaging difference in aznas but the modem is same.
- wkw62Aspirant
