Cajun65's avatar
Cajun65
Follower
Dec 30, 2015
Netgear Genie will not work on my new Windows 10 machine
To Whom
I just got a new laoptop computer with windows 10 and Netgear Genie will not open, it does a short search and then wants to shut down the Genie.
My new laptop has window 10 has Windows 10 Pro 64-bit.
The Netgear is a N600 WiFI Cable Modem Router (C3700) [as listed on the box it came in].
I bewelieve I have downloaded the latest Netgear Genie for my laptop. It does allow me acfcess to the internet and/or sites I choose.
Really could use some help.
Thanks
Paul
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello cajun65
    Have you tried to open the genie software as administrator? also may want to reinstall it.
    DarrenM
    • docbhill's avatar
      docbhill
      I am having the same problem and I have reinstalled the software numerous times but still have the problem where the program does not want to start.  I'm assuming this is due to compatibility issues.  Please help.
      Thanks
      Barron
      • nickva0517's avatar
        nickva0517
        Tutor
        I had the same situation following Windows 10 install.  I went to Netgear to find the latest Genie install, downloaded, and installed.  Seems good as before when I was on Windows 8.1.  Hope that helps you.
