gamalielreeves
Aug 26, 2015Aspirant
Netgear Genie
Good evening. Recently purchased a Netear C3700 router and I have also downloaded the Netgear Genie. I attempted to do the set-up, however the program will not allow me to continue, advising me to log into my OpenDNS account. I have established an account and subscribed to a network however the Genie program still will not allow me to go further (complete the installation). Any suggestions?
- Babylon5NETGEAR Employee Retired
You can also try setting up the router by logging into its web interface using a Web Browser. This will give you direct control over the router settings and you should be able to run a setup wizard from there. Do you have the manual for the C3700? http://www.downloads.netgear.com/files/GDC/C3700/C3700_UM_21Aug2014.pdf
- gamalielreevesAspirant
Andy thank you so very much. Your suggestion worked. Set-up has been completed.
