k9arjun
Apr 22, 2019Aspirant
Netgear Nighthawk C7000 for centurylink 1 Gig fiber
Hi All,
I own a 'Netgear Nighthawk C7000' with Xfinity and I was very happy with Netgrear speed and performance.
Recently I switched to Centurylink 1 Gig fiber connection, and I found 'Ne...
Apr 22, 2019Guru - Experienced User
What is the wired speed when the C7000 is connected as the modem?
Is the C7000 being used as the primary modem? If not then the C7000 may not be needed.
You shouldn't have two routers on the same line.
You'll not see much over 400-500Mbps on wifi depending upon wifi device support. Not alot of devices support much over that on wifi. Wired LAN should see 900Mbps + or -.
k9arjun
Hi Furry,
Thanks for reply.
There is no WAN port on C7000, so I tried to like this ,
1Gig Fiber cable -> Centurylink modem router (ZyXEL C3000Z) WAN
Centurylink modem router (ZyXEL C3000Z) LAN to C7000 LAN
C7000 LAN to my mac
Then speed around ~250.
I will be happy If I get WIFI around ~250.
If i am not doing, Please redirect me to correct direction!
- plemansApr 22, 2019Guru - Experienced User
the C7000 doesn't support router only mode. It is a modem/router combo device. You can disable the router aspect of it to function as a modem. Not the other way around.
There's a work around on this forum for C6300 that would be similar. https://community.netgear.com/t5/Cable-Modems-Routers/Can-I-use-a-C6300-cable-modem-without-cable-internet/m-p/1463500
It doesn't mean you'll get the performance of a router only if you get it working. Its just a way to maybe make it function decently and without a double nat situation.
- FURRYe38Apr 22, 2019Guru - Experienced User
You really can't use the C7000 like that.
The C series modems only works at gateway routers or in bridge mode which means when in bridge mode the router and wifi portion of the modem is disabled.
