Mattmtz's avatar
Mattmtz
Netgear nighthawk c7100v cable modem router name and password change
I have a connection and ive activated it twice but everytime i go in ti change the name of the wi-fi and password, it says it has a “configuration error the router could not apply my new settings. Check wifi connections and try again.” I check and my wifi is working but i cant change the name or password? Please help.
    How are you trying to change the Wi-Fi configuration?  Are you using a mobile device like a phone or a tablet?
    If yes, you need to change to a real computer with a web browser and connect to the C7100v via an Ethernet cable.  If not possible with an Ethernet cable, a connection via Wi-Fi should work.
    • Mattmtz's avatar
      Mattmtz
      My modem is connected via ethernet cable and yes im trying to change it on my phone
      • Kitsap's avatar
        Kitsap
        Master
        To a computer?  If yes, Mac or Windows?  If Windows, version 10 or 11?
        What web browser are you using?  Edge? Firefox? Chrome? Something else?
