K9cop1142's avatar
K9cop1142
Netgear Nighthawk CM1150V
I am having a constant problem with loosing signal I have had to reboot the computer / modem /router 4 times again. I have optimum online service . Technician the last time tells me the modem is bad and is loosing signal the other 5 techs told me either a modem works or doesn't . any feedback appreciated.
  • plemans's avatar
    Do you have a screensnip of the cable connections page and event logs?
    Also, if you hardwire a pc/laptop into the modem (without anything else connected) does it stay stable?
      • plemans's avatar
        K9cop1142 wrote:
        Modem to router to computer hardwired .
        that adds next to nothing.
        1. The cable connections page and event logs show us the connection back to the isp
        2. I don't really care a whole lot about the router. I don't want it connected to the modem for testing stability.
        When you have a modem and a router and you're getting drops, the goal is to simplify down to just modem/pc to ensure that connections stable first and its not a router issue making it seem like a modem issue
