Deborah2323
May 08, 2022Aspirant
NETGEAR Nighthawk Multi-Gig Cable Modem CM2000
Is it possible to use the Netgear Nighthawk CM2000 in Germany with my Orbi (RBK852) routers? Thanks!
- Deborah2323Aspirant
Does anyone happen to know if I can use my Netgear CM2000 Modem in Germany? And if so, are there any special set up instructions I need to know?
Thanks.
Ask the ISP in country if they support cable modems. Some may not.
Thanks.
Thanks.
Maybe someone with the same ISP hangs out here.
So tell people which ISP this is and maybe someone can help.
You could also try here:
NETGEAR Forum - NETGEAR Communities
- olympos1625NETGEAR Employee Retired
Hi @Deborah2323,
Welcome to NETGEAR Community!
Thank you for reaching out. We are sorry for not being able to get back to you immediately. The CM2000 is a North American DOCSIS standard and won't work with European DOCSIS.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
Yes. Review the online Installation guides for additional information:
