KLD
Oct 09, 2015Aspirant
Netgear Router Exploit - 10/8/2015
So, apparently my router has been hit in this recent exploit. I am unable to log into my gateway using my current password that worked the last time I logged in. This is done via Lastpass so I know i...
- Oct 17, 2015
Did the reset cause I was all out of options. Worked as expected. Thanks for the idea.
DarrenM
Oct 09, 2015Sr. NETGEAR Moderator
Hello KLD
The way to get back into the settings is to factory reset the device by holding down the button with a paper clip for 10 sec this will default it back to admin and password as the password then you can go back in and set it up.
DarrenM
