KLD
Oct 09, 2015Aspirant
Netgear Router Exploit - 10/8/2015
So, apparently my router has been hit in this recent exploit. I am unable to log into my gateway using my current password that worked the last time I logged in. This is done via Lastpass so I know i...
- Oct 17, 2015
Did the reset cause I was all out of options. Worked as expected. Thanks for the idea.
jlewter
Oct 09, 2015Guide
Do not enable remote logins at all.. Also go through the router and add passwords in any place that accepts them..
If an option is greyed out but there is a empty password box, turn the option on, add the password, then turn the option back off!...
So these new forums, are they in MM/DD/YYYY format, or DD/MM/YYYY ? ....
