Oppakj
Apr 19, 2022Aspirant
Netgear router not connecting
Why is my Netgear router not connecting from last week ? even i have checked my entire system
1. what router do you have?
2. what firmware is on it?
3. what modem/gateway is it connected to?
4. what are the led's on it doing?
5. did something change?
6. what have you tried doing to fix it?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Its a great resource to start with. - OppakjAspirant
netgear router model c6300
C6300 V3.01.14 V2.01.14 - plemansGuru - Experienced User
Well, you answered the modem/router/firmware question and then marked it solved.
I take it you got it working again?
If not, the reset of the questions are helpful to answer.You can find manuals/guides here: https://www.netgear.com/support/product/C6300
- BettyPayetonAspirant
I have fixed the problem myself, they said my new netgear support had been canceled because they could not fix my problem, I just wanted to make sure. They had me buy a maintenance plan that I do not need now. The problem was the ethernet cable.
CAT6 LAN cable is recommended.
