Sep 15, 2024Guru - Experienced User
New - CAX80 Firmware Version 5.1.1.8 Released
New Features and Enhancements: 09/10/2024
- Smart Parental Controls
- WPS PIN and ReadySHARE Vault support removed
Bug Fixes:
- Fixed security vulnerability issues.
- Fixed various bugs.
Other Fixes: Should fix the 5Ghz Upload issue and cell phone text message sending of pictures. Also Nest Controller App connectivity.
Firmware Update Instructions:
Download Link: https://www.netgear.com/support/product/CAX80.aspx#download
NOTE: The .bin file is embedded with in a .rar file. Use any uncompressed/unpacking program to unpack the .rar file with in the .zip file to reveal the actual FW .bin file. It's there. 7zip is a free app.
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/
enter your model number in the search box, and click the Documentation button on the product page.
NOTE: This upgrade is for the ROUTER portion of the CAX only. Modem portion Firmware upgrades are pushed down by your ISP. For more information, please see our https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-modem-router
Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
This article applies to:
Let us know how it works for you...
Even with this new firmware, I am still having issues sending pictures over 5 GHz, and have to switch to the 2.4 GHz to send them. This is even after a factory reset of the device.
Are there some settings I need to enable or change for the fix?
Who is the ISP that your connected with?
What channels are you using on the modem?
Is Smart Connect enabled or disabled?
Is AX mode enabled under basic wireless settings?
Is MIMO enabled?
Is IPv6 enabled or disabled?
Xfinity/Comcast
5GHz is on channel 36.
Smart Connect is disabled.
Yes, AX is enabled.
Is MIMO enabled?
MIMO is enabled.
IPv6 is enabled.
