AVab
Dec 01, 2017Aspirant
New C7100V Running Slow!
Now Model C7100V - not available from the drop down model selector!!!! I just purchased a Nighthawk C7100V Cable modem, Router, and WiFi for use on XFINITY X1 Triple Play. The installation an...
AVab
Now that I got through the bad documentation and have my C7100V setup and functional, it is running WAAAAAAAAAY slow. The Arris TM822 telephony modem I replaced was getting 270 Mbps down and 30 Mbps up. The best I can get with my new 960 Mbps rated Netgear C7100 is 177 up and 24 down. Any ideas?
The MTU is set to the default which is the Max - 1500.
zinca
Jan 31, 2018Guide
Did you get anywhere with this? I was getting 300 Mbps but having some connection issues. Put the 7100 in bridge mode, and now only getting 95 Mbps. Huh?
- AVabFeb 01, 2018Aspirant
My issue turned out to be a xfinity provisioning error. They downloaded the wrong file to my modem which caused the slow performance.
- Ed_DowdyMar 14, 2018Aspirant
I am running slow again. I turned off the router mode once a couple weeks ago and lost all internet access. I thought I had my sloww issues resolved, but I noticed Comcast updated the firmware to 2.01.33. Now one second it's 180 down the next it's 3 down.
- Ed_DowdyMar 15, 2018Aspirant
Chock my problem up to operator error. Had device prioritization turned on in Velop app.
