ramjr2020
May 14, 2020Tutor
Nighthawk® Multi-Gig Speed Cable Modem for XFINITY® Voice (CM1150V) MoCA?
A simple question, but I can't find an answer. Does this modem support MoCA?
If not, if I set up MoCA adapters, will it work? I understand that MoCA 2.5 and DOCSIS 3.1 may have problems with overlapping frequencies, but I'm fine with MoCA 2.0, if needed.
Thanks.
No it doesn't.
If you're adding moca adapters they need to be setup off the router.
so CM1150v-----router-----moca adapters
Check the sped data sheet to see if MoCa is listed in the specs section, if you don't see it there, I presume the modem may not support it.
Hi,
Thanks for the suggestion. The problem, not clearly stated, my apologies, is that the technical specs said nothing, and I wanted to be sure it was not just missing by accident ;)
And with the second response confirming your position, I can move forward with my hardware requirements.
No it doesn't.
Could you explain why the moca needs to connect to the router? In particular, my plan was a wireless AP connected to one of the modem's RJ45 posts, one for moca, and one to a switch. The fourth could be a spare or directly connected to a desktop.
With no router, should I connect the moca to the switch instead?
Thanks.
- plemansGuru - Experienced UserSure. The CM1150v is basically a modem without a router. your isp assigns 1 public ip address to your account through the modem. That is whats provided to the router which then assigns private ip addresses to the devices on the network.
You can go modem-----moca-----moca----router since in effect its passing that 1 address to the router. But if you're trying to attach multiple devices without a router, only 1 device will get an ip address.
The extra ethernet ports on the CM1150v aren't well educated to the public for them. Both on netgear and the ISP's side.
For the average consumer, they're worthless. Some can use port 1-2 for wan port aggregation. The rest can only be used if the isp supplies multiple public IP addresses which the majority of isp's don't do.
