chizwiz
May 05, 2016Follower
Nighthawk AC1900 compatibility with Comcast voice on separate adapter
I see that the description for the Nighthawk AC1900 says it's not compatible with bundled internet and voice serice. However, in my case I have Comcast Business internet and voice, but the voice coa...
doraemon
May 11, 2016Prodigy
Your voip is not connected in anyway to your existing modem right?
As you can see the modem router doesn't have a voip port.
Therefore, you should be able to replace it without a problem.
