DannyS22
Dec 12, 2021Guide
NightHawk AX2700/CAX30
Nighthawk ax2700/cax30
firmware 1.4.10.8
I'm on Xfinity cable with their More Speed Plan (I think)
Seems that every 2 weeks I need to power off/power on the unit to get back my speeds. As an example my USB 3.0 WiFi adapter will run on Speed Test 490+Mbps or on my Android Samsung S20+ at 640Mbps then both it will slow down to 280Mbps.after 2 weeks. Redo the power reboot and things go back to the higher speed.
Any ideas is appreciated.
Thanks
Danny
Keep us posted.
DannyS22 wrote:
I still don't see anything called WMM under the advance wireless setup
I've changed the channels but I get a message on the 5Gmhz that says To get best wireless performance Netgear recommends set gateway to a high channel between 149-161. I proceded to 48.
It will take a while to see if things change.
Thanks for the help.
danny
Does a ethernet connected PC experience same issues?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Is Smart Connect enabled and WMM enabled?
- DannyS22Guide
Let me see if I've got the right info.
NO Ethernet connections ALL wireless.
Wireless Setup
Enaable AX
2.4Ghz
Enable SSID Broadcast
Enable 20/40 Mhz Coexistence
Channel Auto: Current 8
Security: WPA-2 Personal [AES]
5.0Ghz
Enablr SSID Broadcast
Channel 153
Current 147+153(P)+157+161
Security WPA-2 Personal (AES)
Maybe 1 neighbor with a WiFi
SMART is NOT enable and I don't know WMM (sorry)
Seems to me as a novice, it's like resetting the connection. I don't know if Xfinity is throttleing me. According to their website, I'm not close to data limit, if there is one.
THANKS for the help, I appreciate it.
Danny
- FURRYe38Guru - Experienced UserSo try this, Disable WPA security on the modem temporarily. Connect 1 device up to the CAX while the wifi is in the open. See if it will connect and gain internet services. Re-enable WPA2 and AES after testing.
Wireless Setup
Enaable AX
2.4Ghz
Channel Auto: Current 8< Try channel 1, 6 or 11.
5.0Ghz
Channel 153
Current 147+153(P)+157+161< Try channel 48.
SMART is NOT enable and I don't know WMM (sorry) < Under Advanced Tab/Advanced Settings/Wireless Settings
Danny
