Moscowsteve
Aug 27, 2017Aspirant
Nighthawk C6300 and FiOS Quantum Gateway AC1750 and Chromecast and other problems
Hi, ultimately i just want wifi to work in my house the easiest way possible that does not continuious die on me.. I've spent this month another 20-40 hrs trying to resolve the above three ite...
DarrenM
Aug 31, 2017Sr. NETGEAR Moderator
Hello Steve
You would want to turn the DHCP server off on the C6300 It is under Advanced-Setup-Lan Setup and uncheck the box this will stop the conflict between the 2 routers.
DarrenM
Moscowsteve
Aug 31, 2017Aspirant
Darren thanks for reply. Inder advance i see wireless settings, port fwding, dynamic dns, remote mgmnt, upnp, usb settings , and ipv6. Now when i look inder all of them i only see under dynamic dns. The check box use a dynamic dns service and its not currently checked. Hummm. Checked again. Under advance/ setup/ lan settings the box use gateway as dhcp server is checked. Assume i am to uncheck. When i do this i loose ability to loginto router using routerlogin. So an i still able to login?
