janedoe
Jun 11, 2016Follower
Nighthawk C7000 Cannot change time
I have the Netgear Nighthawk Model No. C7000 and the time is showing as 1 hour early. How do I change the time to the correct time? There is no option to change the time in Advanced -> Security -> ...
wilcrd
Oct 10, 2016Aspirant
I am having the same problem with the time.....I am one hour late....I noticed this when I set up a schedule for wifi to be off and come back on. It was one hour late.
I started to look for a time zone setting like I have on my R7000 ...but I cannot find that setting on the C7000....Why is the firmware so screwed up...it also says it is European settings....but I remember reading that does not hinder the settings for US??? If that is true why do they even have a Europe or US choice??
I think this modem model is a year old ? So why hasn't there been a firmware upgrade fix for all these problems?
DarrenM
Oct 12, 2016Sr. NETGEAR Moderator
Hello wilcrd
All the firmware for the C7000 is pushed out by the cable ISP and also the ISP servers push the time data to the modem.
DarrenM
